type 209/1200 Hellenic Navy 10 Jahre 5 Monate her #27047
  • bassplayer1
  • bassplayer1s Avatar Autor
Perhaps you can solve it as with the originals, enclosed follow a few pictures. Here to move only a course/pressing rod used around both rudders. The trick is the dead angle that a rudder puts back in each case.
Best Regards, Klaus
Klaus, thank you very much indeed! The plans are fantastic and answer all my questions! Thank you again!
Regards Yannis
type 209/1200 Hellenic Navy 10 Jahre 4 Monate her #27111
  • bassplayer1
Hallo everyone!
Making the WTC and the ballast tank. The pipe going through the tank is for the trim tank.
type 209/1200 Hellenic Navy 10 Jahre 4 Monate her #27207
  • bassplayer1
Hallo from hot Corfu!
Still working on the WTC and also finished with the bow planes mechanism. Now it works really good(thanks a lot Klaus!!!)
type 209/1200 Hellenic Navy 10 Jahre 2 Monate her #27835
  • bassplayer1
Hallo my friends!
Progress is really slow due to other obligations but getting there! Finished with the WTC and it was checked for water leakage! Everything was OK so I've started putting in all the bits and pieces! Also I've installed the prop shaft and propeller, checked it and works fine! Here is some photos and a video!
Regards Yannis
www.youtube.com/user/bassplayer12100?feature=mhee
type 209/1200 Hellenic Navy 10 Jahre 2 Monate her #27837
Hey, is this a carburetor?
type 209/1200 Hellenic Navy 10 Jahre 2 Monate her #27852
  • bassplayer1
Hi Stefan
Yes, it's a carburator, ha,ha! I know it's a primitive solution but it works just fine as a release valve! I'm going to change it later on with something more sophisticated but at the moment the budget is really low and I'm dieing to get this boat in the water so I use and recycle anything that lies in the workshop and does the job!!!
Regards
