Using 2 receivers in 1 submarine 14 Jahre 2 Monate her #24092
  • sunworksco
  • sunworkscos Avatar Autor
Is it possible to use 2 receivers in a submarine and control it with 1 radio.
I have a Robbe F-14 radio.
Regards,
John
Greetings,
Using 2 receivers in 1 submarine 14 Jahre 2 Monate her #24093
Hello,
2 receivers (or more) in one model with 1 radio?
No problem.
The second receiver must have the same frequency/channel.
Using 2 receivers in 1 submarine 14 Jahre 2 Monate her #24094
  • sunworksco
Thank you.
I am building a water tight compartment tube with a stainless steel piston ballast tank with polycarbonate tubes on each end and do not want to run exterior wiring.
Regards,
John
Greetings,
Using 2 receivers in 1 submarine 14 Jahre 2 Monate her #24096
Do you want to use it as redundant configuration?
Using 2 receivers in 1 submarine 14 Jahre 2 Monate her #24099
  • sunworksco
One receiver will control the prop motor,rudder and elevator.
The second receiver will control a piston ballast tank,dynamite gun and torpedo.I do not have access through or around the piston ballast tank since the piston ballast tank is the same outside diameter as the water tight container tubes on each end of the ballast tank cylinder.I do not want my electrical wiring outside as well.
Regards,
John
Greetings,
Using 2 receivers in 1 submarine 14 Jahre 2 Monate her #24100
That will work, i did the same in a Leopard Tank of a Friend of mine to reduce wiring from the Chassis into the Turret.
