Robbe F-16 Radio 40MHz 15 Jahre 11 Monate her #24651
  • sunworksco
  • sunworkscos Avatar Autor
I am in the USA and use, legally, synthesized RF 75MHz and 2.4GHz radio frequencies in my Robbe F-14 radio.
I really like the Robbe F-16 radio and I am inquiring to know if I can install a 75MHz RF TX module and also a 2.4GHz TX module in this radio to create something very special for use in America.I hope there is some way to make this work.
Kind Regards,
John
Greetings,
Robbe F-16 Radio 40MHz 15 Jahre 11 Monate her #24654
  • Wheelerdealer
  • Wheelerdealers Avatar
Ja, Sie können, erfordert es ein bisschen Operation, um den Stift aus Antennen der 75MHz-Modul mit dem HF-Teil des FC16 PCB (als würden Sie mit dem 2,4-GHz-Modul zu tun) löten.
Yes you can, it will require a bit of surgery to solder the pin out antennae of the 75MHz module to the RF section of the FC16 PCB (like you would do with the 2.4ghz module).
Ramesh
Robbe F-16 Radio 40MHz 15 Jahre 11 Monate her #24661
  • sunworksco
Thanks Ramesh,
Can you please post some drawings.I am getting ready to buy 2 of the Robbe F-16 radios and convert them to the Futaba FSM-75 RF module/Jeti Duplex TU 2.4GHz RF module combination.
Kind Regards,
John
Greetings,
