Bau eines Tauchtanks 16 Jahre 9 Monate her #21085
  • 17bs Avatar Autor
Well, maybe its because of former mails he had with you?
Bajonett Rings maybe? I just guess...
Bau eines Tauchtanks 16 Jahre 9 Monate her #21086
17b schrieb: Nun, ich habe in der Zwischenzeit die Erfahrung gemacht das eigentlich ALLE Anbieter Support leisten.
Nun ja, da gibt es eben halt auch andere belegbare und lehrgeldreiche Erfahrungen. :wink:
Bau eines Tauchtanks 16 Jahre 9 Monate her #21087
  • 17bs Avatar Autor
Ich weiss...
Bau eines Tauchtanks 16 Jahre 9 Monate her #21100
  • Subculture
  • Subcultures Avatar
Hi Stefan,
Nice to see this sort of thing built up. Does anyone build the pulley spindle detailed in Norbert's book when making piston tanks?
Also was that a solvent you used for bonding the end cap on your tanks, or a two-part adhesive?
I thought of bonding them on with something like Sikaflex.
Bau eines Tauchtanks 16 Jahre 9 Monate her #21101
  • 17bs Avatar Autor
Andy, the glue i use for the end cap is called UNI 100 made by Griffon.
Its a hard PVC solvent Cement and used to glue plastic pipes together.
I am sure you will get something similar to this in UK.
Sikaflex might work as well, but i would check this before.
What do you mean with pulley spindle? Got a Picture?
Bau eines Tauchtanks 16 Jahre 9 Monate her #21111
  • Subculture
Don't have any pictures, sorry. Never seen one, just read about it in Norberts book, 'Model Submarine technology'. I'll attempt to describe it.
It's really a cheap form of ball screw, instead of using a threaded nut bolted to a gearwheel, you machine three small, threaded wheels which are ballraced and fitted to a spigot at 120 degree intervals, which attaches to the gearwheel. The three wheels engage the thread to get linear action, but because the area of contact is much lower than a threaded nut, you get much less friction.
I believe Norbert used this in his 'Forelle' model some years back, but no pictures were published of the device.
Andy
