Futaba ESC/BEC/Data-Logger 15 Jahre 11 Monate her #24445
  • sunworksco
  • sunworkscos Avatar Autor
I am interested in using the Futaba MC950CR Brushless ESC but it is difficult to find.It seems to be a fantastic esc.
Regards,
John
www.futaba-rc.com/radioaccys/futm0955.html
Greetings,
Futaba ESC/BEC/Data-Logger 15 Jahre 11 Monate her #24446
Hello John
for my opinion this controller is al little over sice:
Max current: 900A (Momentary load: 1300A)
But only
Input voltage: NiCd / NiMH 4~7 cells (4.8V~8.4V)
and
BEC: 6V / 2A
If you need an fantastic Datalogging look here:
www.sm-modellbau.de
If you need an good brushless controller have a look here
de.robbe-online.net/rims_de.storefront/4...ct/View/1&2D8631 or other parts of this family.
Nils
Futaba ESC/BEC/Data-Logger 15 Jahre 11 Monate her #24457
  • sunworksco
Thanks!
I am considering the Data-logger now.
I am looking at the AquaCraft ESC though.
What do you think about this esc ?
Regards,
John
www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMYB8&P=FR
Greetings,
Futaba ESC/BEC/Data-Logger 15 Jahre 11 Monate her #24477
Do you really want to buy a ESC with knowing only the maximum voltage and the current?
If the manufacturer has no need for further information, he also has no need for your money.
There many well documented controllers on the market, you should take one of them.
Dominik
