Submarine Props 18 Jahre 10 Monate her #11936
  • Wheelerdealer
  • Wheelerdealers Avatar Autor
Heres my custom prop for a 1/54 Alfa, 93mm dia.
Built by www.gsitek-props.co.uk/
Cost was about £30. Solid brass with M5 thread. I supplied the pictures and drawings with dimensions.
Turned out very nice :)
Ramesh
Submarine Props 18 Jahre 10 Monate her #11937
Cool, is the Prop cast in brass or is he welded?
Submarine Props 18 Jahre 10 Monate her #11938
  • Wheelerdealer
Hi , the blades are soldered on, cast prop will cost a lot more for a custom prop. Maybe if it was a large order they could be cast :?:
Still its pretty good, you have to look closely to notice the solder.
Ramesh
Submarine Props 18 Jahre 10 Monate her #11939
  • Subculture
  • Subcultures Avatar
It's not the casting that costs, it's the development of the master and subsequent rubber moulds to produce the green wax tools for investment casting.
If you can provide a green wax master ready for coating in investment, then the cost of prop shouldn't be any greater than an off-the-peg variant.
Andy
Submarine Props 18 Jahre 10 Monate her #11946
Last Question, are the Blades cut from thin Sheets of Brass or are they profiled? If not profiled, i can also use Raboesch Props, available in our local store.
Seems, that nothing compares to Propshop...
Submarine Props 18 Jahre 10 Monate her #11948
  • Wheelerdealer
Yes, the blades are profiled.
Ramesh
