SCALESHIPS AKULA II Einbauen des Druckbaehlters von ARKMODEL 14 Jahre 7 Monate her #28957
  • arkmodel
  • arkmodels Avatar Autor
Scale ships has provided the best Akula kit in the current market.The scale of original Akula kit is 1:96,just fit for arkmodel series WTC .
While the Hull of Scale ships is very thin ,if want to make the ship to sail ,we must to use Boxian cloth to firm inside.
The scribed line in the surface of the hull is very meticulous .
This ABS board is used for installing Mast Elevation system
In order to get the best effect,this sub use many LED in different parts .
To install WTC ,a specialised positioning board for it .In a word ,it is not so difficult .For the series WTC matches very well in this similar size submarine .And do not need to modify the WTC itself .
The connect of WTC ,Servo and shaft is as usual,do not need to make too many modifiction.
The front cover of WTC ,Provide 16 siginals the most and 4 power input/output.The black in the picture is the Rubber seal cover,which is used for Sealing mouth charging.When needs to charge ,take off the sealed cover ,it is very conventient for charging
Perfect surface
The propeller charged to 039 song class Nylon propeller,except for it nearly looks the same as the orininal.Besides ,the propeller of 039 is enough in stock ,and is very economic .So please be ease to use
