Robbe F-14 Navy Radio 2.4GHz RF Module Conversion 15 Jahre 6 Monate her #25209
  • sunworksco
  • sunworkscos Avatar Autor
I want to hack my Robbe F-14 radio with a 2.4GHz Hitec AFHSS RF module. Can anyone please post a drawing for where to plug in the Jeti TU2 toggle switch and wiring harness. I am keeping the Robbe F-14 factory RF and want to switch between the two RF modules.
Thanks,
John
The RF module is out of the case.
Greetings,
Robbe F-14 Navy Radio 2.4GHz RF Module Conversion 15 Jahre 6 Monate her #25210
John, this is in German and about Graupner, but maybe you can use it
Robbe F-14 Navy Radio 2.4GHz RF Module Conversion 15 Jahre 6 Monate her #25213
  • sunworksco
Did I miss something? :-)
Regards,
John
Greetings,
Robbe F-14 Navy Radio 2.4GHz RF Module Conversion 15 Jahre 6 Monate her #25214
Oh, sorry...
Here we go!
www.mikrokopter.de/ucwiki/JetiDuplex
Here is someting about a F14 Mod
www.peter-voigt.de/pages/steuerungen/futaba-f14.php
Robbe F-14 Navy Radio 2.4GHz RF Module Conversion 15 Jahre 6 Monate her #25218
  • sunworksco
I thought perhaps the Jeti TU2 switch with wiring harness could simply be plugged into the trainer plug on the Robbe F-14 PBA?
I'm still not sure how to do the conversion now that I am not using the Jeti RF module and instead using the Hitec RF module.
Thanks,
John
Greetings,
Robbe F-14 Navy Radio 2.4GHz RF Module Conversion 15 Jahre 6 Monate her #25223
You also have to keep in mind that the F-14 in the description is the old 7-channel version.
I am sure that it is possible to connect this Hf-module to the F-14, but I don't know how.
You should look for an instruction for your Module (or any other Hitec module) and the F-14-
Dominik
